Screen is dark and does not turn on? The off and on light - red and green are both blinks - red - green - red -green?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
SOURCE: Fujitsu Plasmavision 55"
Hi, The problem comes from the power supply board. The power supply board is a three phase unit. One phase on the power supply failed, that would be the reason for the no picture. You can have the power supply board repair or replace. If you are within the manufacturer warranty, they "should" replace the part ( power supply board) at no cost to you. Mike
SOURCE: Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
SOURCE: P42vHA30 - picture disappeared and
I would suggest taking a look at the power supply board and making sure there is nothing that has went bad such as fuses, capacitors, transistors, etc.
