Doesn't print; the green light just blinks. Doesn't print; the green light just blinks. Doesn't print; the green light just blinks.
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: Flashing lights and no printing
If the two lights are blinking persistently and the carriage is moving freely when the cover is opened then the logic board has problem and should be replaced. However, if there is some restriction of carriage movement or cracking noise, the optical cable should be replaced. Good luck
SOURCE: Green light is blinking, but not printing.
if you using this printer by network - clean any quue from other computers :) good luck
SOURCE: LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
