I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 97 Answers
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
Posted on Sep 19, 2014
5 Suggested Answers
6ya staff
SOURCE:
jan mczeal
Jan McZeal
  • 632 Answers
SOURCE: Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Posted on Jan 20, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: F02 Error Code on Kenmore
Hello, welcome to FixYa.
Based on your information posted I understand you have the Kenmore HE3t washer, correct ?
Reading your description and factoring in all you've done and inspected, it may in fact be a faulty pump...(the F02 ultimate worse case) even if it is draining slowly it does not rule it out, trust me I've seen many of them.
By reading your post I've gathered you are pretty thorough so I don't expect you missed it, but I must mention it or I wouldn't be thorough either, I think you can appreciate that, have you checked the back-flow/check ball ?
If not, here's how...
Pull the boot off if you have not and just see if anything has got in there to obstruct the "ball" from working correctly. It is shown here...(this is from the back, but you can do it from the front...just not as easily...in my opinion)
Undo the clamp and inspect inside...if you have not already.
It's amazing how often I find this ball "stuck" or the bellows clogged with debris of all sorts of items...definately worth looking into before declaring the pump has failed. Good luck. Let me know how you make out as I said and if I can help you in any manner going forward I will do whatever I can.
I've also included a more thorough link of my repair tip below
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Regards,
Macmarkus :)
Posted on Sep 11, 2011
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: I have a Whirlpool DUET that continually gets F02
"F02" is a Long Drain error (as you well know by now). The error code is generated when the drain time exceeds 8 minutes. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
I applaud your effrots. You isolated the source and did all the necessary steps required to clear this error code, but if you perform all these preliminary measures and still have problems, the rule of thumb is to replace the pump.
The "SUDS" error can occur in conjunction with the "F02" error. If the pump is not functioning properly and air is detected in the drainage system, you will get the SUDS error as well.
"F09" is an overflow condition error code which has many causes, inlcuding the drain pump. Everything seems to point to the drain pump in this one. Replace it and your problems may go away.
A replacement can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 02, 2009
Testimonial: "Fantastic, you read my description, confirmed what I've already done, and told me what to replace and where to get it. You went above and beyond ...!"
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: I have F2 code and need to clean out the drain
Welcome to FixYa.
This is a general remedy for most Whirlpool made front-load machines, such as Whirlpool, Kenmore, Maytag, Amana etc. The "Sd" or "F2" is the same as F21 on most Whirlpool washer's and indicates the machine has detected too much soap or a obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
**This is also the reason for a no spin & the "suds" message if applicable**
Here`s how to check it and clean it...
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the Sd or "F2" or "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the Sd, F2, F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today. Good luck
Posted on Feb 23, 2011
My maytag washer bravos quiet series 300 stopped in the middle of a clean washer cycle with the message LD in the time area. Now it is beeping and won't stop. 26 minutes were li
LD generally means a long drain. This can be caused by debris in the pump or a damaged pump motor or impeller. You'll need to unplug the washer, secure the lid with duct tape. Slide the washer forward and remove the inlet hoses. For the Bravos line, you need to tip the washer forward. Let the front of the machine rest on the floor. Now you can access the internal hoses that connect the drain pump and re-circulation pump to the washer tub. Separate the hoses from the pumps and check inside them for debris. Note: have a bucket and towels ready to catch the water that may be in the hose, wash tub or the pumps. Also check the discharge hoses that go up the side of the washer from these pumps. Disconnect the wiring harness and remove the screws that hold the pumps in place. Check the inlets of the pumps for debris. You can use needle-nose pliers to reach some items. Reconnect the pumps and those hoses and tilt the washer back up. Connect the water lines and plug in the washer. Check if the error recurs.
Listen to the washer and see if it tries to pump any water. If needed, replace the pump motor or other drain system parts. This is rare. Usually the washer prevents permanent damage to the drain pump system by stopping.
I hope this helps. Please add a comment with the model number for diagrams of the drain pump and hoses.
(The foreign object(s) probably got into the washer during a previous wash cycle. It shifted to block the drain pump system when the water drained during the clean washer cycle.)
Jun 18, 2018 | Maytag Washing Machines
Maytag washer 4000 series show F21
typically there is a "catch chamber" by the purge/drain pump. This collects change and other debris in where the pump forces water to the drain. To find the chamber, there is either a small access door on the bottom or you may have to take front sheet metal off to gain access. This chamber will have a round "cap". Before you remove the cap, make sure you drain all the water with water drain hose into a bucket. Take the cap off and remove debris, then check to see if fins on motor move freely, with slight resistance, before replacing cap and testing. If you can move fins, try putting washer in "drain" position and with a flashlight check to see if fins are moving by themselves. If they are, replace cap and run a rinse then drain cycle.
Apr 20, 2014 | Maytag Washing Machines
Washer 4000 series 4.5 cu ft
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washerlb_icon1.png, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothinglb_icon1.png such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
Nov 16, 2013 | Maytag Washing Machines
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
What does f2 messege mean?
F2 This error code indicates that drain times are longer than expected.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Oct 08, 2012 | Maytag MHN30PDAWW High-Efficiency...
F2 error code flashes and machine wont finish the drain cycle
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
Our Front loading High Efficiency Washing Machine (Maytag) had a F2 code flashing and I can't locate the manual after I moved. Could you help diagnose the problem?
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display sud and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 02, 2011 | Maytag MAH8700A Front Load Washer
  1. Close the door.
Jan 20, 2010 | Washing Machines
My washer won't drain (code F2)?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to access and check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Jan 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
455 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
