Question about Canon EOS-20D Digital Camera
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Err99 taking pics in sun
  • Claude B
    Claude B Oct 20, 2018
    Hi, I have the same problem. Were you able to fix yours ?
    Prodigy:
    An expert who has answered 500 questions.
  • Canon Expert
  • 527 Answers
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
Posted on Dec 27, 2014
Anonymous
SOURCE:
Anonymous
  • 130 Answers
SOURCE: flashing icon when taking pics
Based on the settings that your camera is in, it is telling you that you are at risk of camera shake. This is just telling you that you can expect to see a blurry picture if you continue to take that picture and that it will slow down the shutter speed to achieve the proper exposure and that is why you are at risk of camera shake. The longer the shutter is open, the more chance that you are going to move so to solve this you have a few options:
  • turn up ISO
  • use tripod
  • use flash
Hope this helps!
Posted on Jun 01, 2008
Anonymous
  • 130 Answers
SOURCE: Canon Powershot A75 Flash Problem
If it is a malfunctioning unit, you may qualify for an upgrade through Canon rather than going out and buying a new one, paying full price, you can get a deep discount through their loyalty program. Give them a call to set your camera up for service and the service technician once they have your camera will let you know if you qualify for the program and which camera you will qualify for and how much it will cost.
Hope this helps!
Posted on Jun 09, 2008
Anonymous
  • 3 Answers
SOURCE: Canon S2 IS - LCD screen is white after taking an outside picture
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem with the camera in the past. There is a defect in the sensor of the camera, and happens quite frequently in this model. I would try and contact Canon about it, and see if they'll repair it for free. If not, its probably going to cost more than the camera is worth to repair it.
Posted on Apr 12, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: White screen for all outdoor pictures
Sorry to say this sounds like a stuck open shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
http://www.fixya.com/support/t295396-canon_s2_black_screen
Posted on May 10, 2009
Ty Price
  • 11967 Answers
SOURCE: My camera is 4 years
Check your ISO...set it to a lower number. You could also go into the menu and find "reset" to set the camera back to factory default settings.
Posted on Sep 14, 2010
Image is burning with the sun light
sounds like either a stuck aperture or you have the camera in manual mode and you need to adjust the setting of either the shutter speed, aperture, or the iso... try just putting your camera in auto and see if yuo still have the problem... if it is taking good pics at night then it is you aperture if you are in auto.. if it does not take good pics at night then it is a bad ccd
Nov 15, 2012 | Canon PowerShot A550 Digital Camera
Tip
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
on Mar 04, 2014 | Nikon Coolpix S4000 Digital Camera
I took pictures at night, on auto mode. The next day I was going to take more pics during the day, still on auto mode. All my pics are almost completely white like the flash washed them out and if you...
Hi. Turn on the camera and go into the menu and find the reset function. Reset it. That may solve your problem. If it does not, you could go for a repair or a replacement. Some shops will give you a free estimate. Joe
4 thumbs up please. ty
Oct 21, 2010 | Samsung Digimax D53 Digital Camera
My sigma 28-200 lens works inside but when outside with the sun behind me it gives err99 Cheers Jon.
If you are useing on a digitel canon it may work inside were it is
darker it needs the iris fully open but outside it need to close down if canot close down it will give a err99 it would need a rechip sigma in the UK can not do this anymore
Aug 15, 2010 | Sigma AF 28-200 Lens
When taking pics of paintings or sculptures,have flashback glare
The glare is from the flash and/or direct source of light behind you or from the reflected angle. The only way to get a super detailed, glare free picture from a 90 degree angle of the surface is with no flash and all sources of light being soft, really bright, and /or indirect. Have you seen the large white inverted umbrella things on movie sets and such? That is what you need. Another option available, which I use on my ebay pics is to take it outside in the sun and take the pic from a slight angle. This gets the big fiery ball off the item and your shadow does not interfere. Cut yourself some slack because the pro quality pics of artwork are done in a professional photography setting like a studio or with lots of on site equipment.
Aug 05, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Re: Blurred Image, horizontal lines, photo taken during the day
my friend ur CCD is getting weak this is the first sign of the problem when u get lines hor and vertcal and sun light pics are blurred and over exposed after that this problem extends to the indoor shots as well pls confirm it thru service centre for 100% ,
pls do rate me i know it is a difficult moment but i helped u in diagnosing ur problem without wasting time
Mar 03, 2009 | Sony DSC-T70 Digital Camera
Dgs 100
If the pink & white pics are a small percentage of your photos you should probably just live with it. I have 6 cameras in operation for 2 yrs & they have about 10% like this. Great pics otherwise. Probably caused by the angle of the sun or reflection of the flash off a nearby object.
Don
Jan 18, 2008 | Moultrie MFH-DGS-100 Digital Camera
Blury and dark pictures
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 11, 2007 | Nikon COOLPIX L4 Digital Camera
Indoor pictures
Dear Kim
Sony Cybershot works on technology of where is checks the srround light, if light is fine (like in Sun or outside) phots are fine. solution to this either replace flash or put some big light on  while taking photos
thanks
Oct 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Canon EOS-20D Digital Camera Logo
330 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
