Question about Apple iPad (16 GB) WiFi Tablet PC
With iPad must I join an internet even tho it is connected to my desktop usb?
I don't know how to connect with the internet on my iPad.
    New Friend:
  • 28 Answers
All the above answers should work- assuming you have a wifi connection at home. Please tell us how your desktop connects to the internet if u need further advice
Posted on Sep 20, 2014
    New Friend:
  • 20 Answers
Simply go to Settings-second down on the left menu, choose Wi-Fi and on the right menu, your home (or wherever you are) wi-fi connection should appear by name. Then simply touch the one you want to connect to. You should see the choice you made on the left menu next to the word Wi-Fi. I only connect my iPad to my computer to charge it occasionally via USB.
Anonymous
SOURCE:
Jim Thomson
  • 1099 Answers
SOURCE: ipad wont connect to internet
Go to settings and then wifi if it is off switch it on and then select your wifi router and enter your password
Posted on Dec 30, 2011
adamlcw
  • 53 Answers
SOURCE: iPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
Posted on Feb 23, 2012
adamlcw
  • 53 Answers
SOURCE: Windows iTunes sometimes won't recognize my iPad when connected via USB
http://www.ehow.com/how_4661194_program-hyundai-keyless-remote.html
this may help you!
netbook 10 pouces
tablette pc
jeff39b
jeff39b
SOURCE: I had bought an ipad
I was very happy when I got my hands on the new iPad. I didn't notice this at first, but when I took the tablet into my backyard, and my iPhone was able to pick up my router signal without a hassle; the iPad didn't pick up the network at all. This became a nightmare for me. A friend suggested trying the "Forget This Network" reset method, which used to work on the older models, but this didn't improve the wifi range at all. Right when I lost all hope, I came across WIRED magazine and found a review of Pong Research cases, After seeing the great feedback on their products, I bought one and it finally solve the <a href="http://www.pongresearch.com/new-ipad.html">new iPad 3 wifi issues</a> . The back cover has a built-in antenna in between its layers, which redirects and boosts the signals and range, allowing me to getting connected from much further away.
Posted on May 29, 2012
charles0285
Charles Williams
  • 160 Answers
SOURCE: iPad 3 Printing
You can download hp eprint from appstore.Works with variety of printers.
Posted on Nov 05, 2012
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
Tip
How to connect your Apple iPad to the Internet
Connecting your Apple iPad to the internet is very simple. When you use a application that requires internet capabilities your iPad will do several things.
-The iPad will attempt to connect using the last Wi-Fi network you used that is available.
-If no network you previously used is available, the iPad will show a list of networks in range. You can then tap a network and if needed, enter a password to join the network. Any network with a locked Icon will require a password. These are secure networks.
-If no networks are available or if you don't choose one, the iPad will then connect over a cellular data network.
What is the difference between a cellular and Wi-Fi network? A Wi-Fi network is generally faster, but covers less of an area. Think of your home wireless network, or a wireless network at a library. It has limited range. A cellular network is generally slower but covers a larger area. Normally, if you are connected to a cellular network you will see a 3G icon or E icon at the top of your device. Also, you normally pay to use a cellular network.
To see all the Wi-Fi networks in range: From the Home screen, choose Settings > Wi-Fi. Tap a network to join it.
-G33k
on May 17, 2011 | Apple iPad 16 GB 3G Tablet PC
My iPad was "reset all setting" and now it only display an usb cable and draws an arrow to the word itunes. It is iPad 16 GB Model A1396, FCC ID: BCGA 1396 and IC: 597C-A1396 How to return it normal?
It is telling you to connect it to your PC or laptop where you have iTunes installed. If you don't already have iTunes installed in your computer, you will need to download and install the iTunes software to it. When your iPad is connected, iTunes will synch and update it if you managed to erase the O/S or other necessary items. iTunes connected via the USB cable is even able to install or update the tablet's operating system. It's not just for music.
Your laptop or desktop will need to be connected to the Internet in order to download updated or original operating system. Just follow the prompts.
Apr 08, 2015 | Tablets & eReaders
My iPad keeps telling me I am not connected to the Internet when I am trying to download ios7.4 upgrade. Yet I know I am.
Internet connections can fail at any point from service provider to your iPad. Just being connected to a wifi network doesn't necessarily mean you still have full internet access. Your modem could be frozen and your wifi router would still seem to be fully functional. Try opening your ipad's web browser and bringing up a couple websites. If you can not get any websites loaded, try troubleshooting your wifi. But if they do load, then yes, you are indeed connected to the internet, and I would recommend restarting the iPad and trying again.
Sep 19, 2014 | Apple iPad 32 GB WiFi Tablet PC
Why cant i access the internet even though i have an internet connection?
Sometimes the wifi connections get messed up. Try quitting all apps, turn the iPad off and restart it. You may want to do this with the units connected to the internet cable as well. You may have to delete the connection and reconnect from your iPad, too. Good luck...
Aug 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
If my computer does not have internet can i still connect to netflix
Can your computer connect to the internet? If it can, it just means that you have a wired internet connection and not a wifi connection on the computer, which means your iPad is just connected to your home network via wifi. If your computer can't access the internet or you know you don't have internet service at home, then you either have cellular service (3G/4G) or your iPad is connected to some other available WiFi from someone else's service.
Aug 15, 2014 | Apple iPad Tablets & eReaders
Problem ipad
Either wrong pass word (phrase) or you don't have an (IP) Internet Provider. I assume you have a wireless device such as a router. If you can find it's name on the iPad in the settings you should be able to connect, even if you have to enter a password (passphrase) as will be requested if set (and it should be). Are you running the browser? How do you know it's not connected? Error messages really help here...
Jack
Aug 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Wifi connectivity problem in iPad 2
You can try forgetting your network and then joining it again by going to settings, WiFi, the network you are on, then "forget this network", then find it again and join it. If that doesn't work, then you could reset all your network settings by going to your settings, general, reset, then press "Reset Network Settings".
Jan 26, 2018 | Apple iPad Tablets & eReaders
Install internet explorer on iPad?
1. Sign up for a free account at www.logmein.com
2. Add your desktop with IE to your logmein account.
3. Install LogMeinIgnition on your iPad (cost $29.99, but well worth it).
4. Now you can access your desktop from your iPad (as long as the desktop is powered up and connected to the net) and search your MLS from your iPad via your desktop
Feb 12, 2011 | Apple iPad 16 GB 3G Tablet PC
When I log on to my I- Pad I get a message box asking me if I would like to connect to a wi-fi connection -- usually an apple or a " customer" site. It then asks for my "password" but...
The iPad will ask you if you want to join WiFi networks it finds. You can only join ones that you have the login details for, or commercial ones that you have paid for (such as btopenzone). If you can use the internet anyway, just ignore them,
Hope that helped!
Dec 15, 2010 | Apple iPad 32 GB WiFi Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
95 people viewed this question
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
