Question about Proscan 42LA45H 42 in. LCD TV
Is there a way to get my proscan tv to come back on its only about 6 mo old and will not come on
The TV was fine one night and the nxt morning I noticed the little blue night was not on and I have tried everything and the store (K Mart) would not take it back can you help
    Master:
  • Proscan Master
  • 362 Answers
Https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
Posted on Jan 26, 2019
  • Proscan Master
  • 3,247 Answers
If TV is only 6 months old then it should be under warranty and the store should help you claim the warranty from the manufacturer.
If blue light not coming means if it remains red then the remote battery may need replacement. Check the manual on this site and confirm if your remote is ok. You can also push the power on/off button on the TV to check if it changes the colour of the light.
42LA45H PROSCAN LCD TELEVISION Manual
Posted on Sep 20, 2014
    Sergeant:
    Champion:
  • 234 Answers
Is there power to the outlet? Check your circuit breakers!
6ya staff
SOURCE:
rainsocket
  • 32 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
Anonymous
  • 814 Answers
SOURCE: Proscan 32LB30Q HDTV Just stopped working--1month old
This unit need to be taken to a service center to repair to be tested for component failure. The PROSCAN website for customer support is www.oncorpus.com. go to the customer support and find out where you can take your television for service. The PROSCAN customer support telephone number is. 1-888-977-6722. I hope this helps you with your problem.
Posted on May 21, 2009
Anonymous
SOURCE: Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Posted on Aug 05, 2009
Anonymous
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Proscan 32LB30QD. Yesterday it was OK. This
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts:
Please post back what you find
Posted on Dec 23, 2009
MY PROSCAN TV WAS WORKING FINE THE OTHER NIGHT AND IN THE MORNING IT REFUSE TO COME ON- YOU HEAR IT CLICK ON AND AUTOMATICALLY CLICKS OFF- YOU ONLY HEAR THE SOUND IT MAKES WHEN IT TURNS ON AND OFF BUT NO...
Chances are there is something shorted on the horizontal circuit or the secondary side of the flyback. Check for shorted diodes or horizontal output transistor. Proscan TVs are usually pretty reliable,well worth repairing in most cases.
Hope that helps...........
Jul 15, 2008 | Televison & Video
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
My 55" Dynex lcd TV
take it back.......could be the power supply board....
cheers
Apr 17, 2011 | Dynex Televison & Video
Parts:
Dec 23, 2009 | Proscan 32LB30QD 32 in. LCD TV
Feb 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Poor sound quality
Hi, I sent an email regarding the issue to OnCorpus (the company who makes ProScan)
This is what I got back:
Thomas,
Follow these steps to correct humming issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
jd@oncorpus.com
I can't confirm if this works at this moment since I don't have access to my TV.
Thomas
Feb 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Proscan 42LA45H 42 in. LCD TV Logo
260 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
