LG Wm2688hnma Front Load Washer wm2688hnma Logo
R
Richard Ratcliffe Posted on Sep 20, 2014
I have standing water in drum every morning.
We have standing water in drum in morning. Washer seems to pump out water after use, never have had standing water after cycle. Have to use drain hose at filter housing to empty water, filter is clear. No error codes on readout.
David Atkinson
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Sep 20, 2014
David Atkinson
Contributor
Level 1:
New Friend:
Answers
27
Questions
Helped
262475
Points
58
Without further information, I can offer three possible issues:
1. The fill value is furred up and is not fully closing (diagnose this by turning off the water after use at the isolator valve - and if no water is getting into the drum overnight, then it is a filling problem and you needn't read on - as opposed to a draining problem in which case read on!)
2. If you have a long drain hose running along the back of kitchen units, perhaps it is running back into the machine
3. Have you installed anything else into the same drainage pipes - such as a waste disposal unit or another appliance - that may be pushing water down the drain so fast, that some returns into other connected appliances?
Good luck
3 Related Answers
Anonymous
  • Posted on Nov 30, 2008
SOURCE: drain pump on my LG
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Anonymous
  • 88 Answers
  • Posted on Dec 30, 2009
SOURCE: LG front load washer does not drain after cycle.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Anonymous
  • 298 Answers
  • Posted on Jan 13, 2011
SOURCE: my LG TROMM washer displays an error code DE when
its the door not closing all the way shane
1helpful
Kenmore front load washer, has water in the drum several days after I wash
IF this is some problem that you had not experienced before, it could be the filter or pump is plugged. The outlet pipe also maybe too high.
There comes black stuff out of the washer when i spin. Isit the stasoft?
Fill your machine with hot water (if you only have cold water connected, then add hot water with a bucket) until the machine is filled to the top mark. Add a cup of dishwasher powder and stir it to dissolve. You can also let you machine run a short while, but be carefull that the water is not pumped out. Turn the machine off and let it stand overnight. Then turn it on the next morning and let it wash a complete cycle. You don't have to let the rinse part of the cycle complete. Just turn the machine off when the first water has been pumped out.
What this does: The machine builds of a residue between the drum and outer housing which is not removed in the normal wash cycle, especially if you don't wash with hot water. LG recommends that the machine is cleaned in the above way once "fluff" or black residue is starting to show in clothes after washing.
Standing water after nonuse
You need to clean out the drain pump. usually located at the bottm fron of machine. clogged drain pump = standing and very stinky H2O.
2answers
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
1helpful
Washer will not drain and is making a louder than normal sound
the pump or the filter is blocked u need to pull the machine out put the waste hose into a bucket to emptey if the water come out quick then the pump is blocked if water comes out very slow u have blockage and need to remove the pump and sump hose
3helpful
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
2answers
Fluff in drum blocking pump
Hi.
You will probably have to remove the hose from the drum to the pump to clear the blockage.
access is from the rear.
2answers
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
