I got the code early morn of 9/20/14-had to go to bed. Didn't test it. Got up this morning and tried to use it for the 1st time on Facebook and it wouldn't take it. I only got it cause I have been hacked before and I didn't want anyone else to get into my Facebhook but me and since I had never used it to get in they wanted me to use it for the first time to get in.
SOURCE: The car will not start
Is your car parked outside the garage?If yes,try park inside and see any difference.
SOURCE: Last fall my 2001 prizm
This should be a relatively easy fix. The reason you were having problems starting the car is because the neutral safety switch was not being fully activated or is broken. Now it seems the shift linkage is either broken or something has come loose. You will need to remove the center console to get to the linkage and see what the problem is. But before you do that check the linkage at the transmission. The shift cable may be broken.
SOURCE: my car was running fine yesterday and this morning
Check for spark and fuel. When you turn the key on you should hear the fuel pump in the tank for a few seconds till the pressure builds up. When you crank the engine there should be spark at the plugs.
SOURCE: Got codes P0401---EGR Valve. P1684---have
P1684 Metering Oil Pump Position Sensor Circuit Malfunction, , on a dodge it means just that , you've disconnected the battery its just a status code,, don't worry about this one,, Now the P0401 Exhaust Gas Recirculation Flow Insufficient Detected,
SOURCE: I was driving my 96
First lets define the codes P 1738 shift time error this is a transmission issue
P1784 Transmission mechanical problem 1st and reverse
P0736 Reverse incorrect gear ratio
P0120 Throttle postion sensor switch malfunction. Here is the fix this now make alot of sense when your TPS sensor fails you will affect the performance of the transmission and hence the transmission codes so replace the throttle position sensor this is much easier than the cranksensor and here is the good thing this sensor has no adjustment just drop and go
