Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mah 6500 spins but leaves som water in tub. if you
Mah 6500 spins but leaves some water in tub. if you spin tub by hand you can hear it moving in water
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Answers
56
Questions
0
Helped
23697
Points
148
They have a balance ring on the front of the tub and it's full of water
My front loader fills with water but then does nothing. The drum doesn't turn. Can hear clicking sound from the control panel as though it's moving through the cycle. Checked the belt and is in good c
Does it spin if you turn to spin cycle?
Try this:
Jam lid switch with something plastic or wood.
Put on spin cycle.
Spin the tub by hand.
If the bowl then starts spinning properly, your problem is the motor starting capacitor.
Constant out of balance on washer
Check the inter tub ring you should hear water when you spin it by hand
if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle
h Tech AL Wojo
When I hand turn the drum I still hear water behind the drum please help
You most likely are not hearing water remaining in the tub. You are hearing the water slosh around in the balance ring that is attached to the spin basket. There is a balance ring attached to the spin basket that is half filled with water. When the basket is turned by hand you will hear the water in the balance ring. This is normal.
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
1helpful
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
OFF BALANCE WHILE SPINNING
spin the drum with hand to hear any noise from the bearings on the back of the drum, the drum should turn freely with no grating noise.
Washer tub will not move on any setting
SOUNDS LIKE A BROKEN COUPLER, YOU WILL FIND THIS BETWEEN MOTOR & TRANSMISSION.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
