The problem you have is that the copper pins that have to contact the contacts of the sd card are bend flat you will have to disasemble the whole camera to fix this not an easy task But doable
You have to check out that if your camera support your SD card(type, capacity size ) or if there is real something wrong with the card. Using a card reader insert to PC and see if the card can be read, if it's OK, formatting it by PC then insert it back to camera and see if the problem can be solved.
Else, If the card can't be read by PC you only have to change it.
I BELIEVE THE REASON IS THE TYPE OF SD CARD.
THERE ARE SD AND SDHC. IF YOU ARE USING SDHC.
I BET THE ONE CARD THAT DOESNT READ IS AN HC. THIS IS ALSO TRUE WITH
OLDER CARD READERS. I HAVE AN OLDER AND NEWER CARD READER.
I JUST HAPPENED TO PUT AN OLDER SD CARD IN MY NEW POWERSHOT SD1300 AND IT READS FINE, ALL NEW CARDS SDHC WONT READ.
I BELIEVE SD IS UP TO 2GIGS AND SDHC IS 4GIGS AND HIGHER.
There can be a problem with the SD card itself. A bad sd isn't common but they do happen. What I would check is that the sd card is compatible with the camera. It can be too big or the wrong type or the wrong speed. As a result the camera can't read the card and just sits there. Your camera manual should show a list of tested sd cards. If not your best bet is to go to a store and bring your camera and ask to try before you buy.
If you can read the sd card in something else then it is most likely compatibility problem. If it can't be read about all you can do is try to format the card and see if that brings it back to life.
The "E30" error code indicates reading/writing data on a SD card has failed.
Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data.
Solution
To clear the "E30" error, try performing the following procedure.
1. Try using another SD card.
If you have another SD card, try loading it in the camera.
If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera.
2. Use your computer's ScanDisk utility to check the SD card for errors.
Use ScanDisk to check the SD card for card error or card failure.
Refer to the instruction manual for your operating system or Windows Help for further instructions.
(If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.)
Be sure to back up the data on the SD card on the computer before you check the SD card.
If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card.
Follow ScanDisk's on-screen instructions to solve the problem.
3. Format the SD card with your camera
Try to format the SD card with your camera.
Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card.
Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors.
If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Solution
Solution
Solution
Solution
