Fujitsu LifeBook T4220 Tablet PC Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tablet pc drops wireless connection randomly
Tablet is used by physician within office to input patient data.
Recieves signal from Linksys WAP4400N routers.
Troubleshooting to date : have tried multiple (POE) and single
router broadcasting with same result.
Have swapped out both routers - no effect.
Suspect internal wireless card - need make and model and
source to replace or upgrade to a better card that is compatible
with this tablet.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jul 03, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737641
Points
36075
Why does my verizon tablet keep disconnecting from wifi and not accepting my pasword to get back on
There could be several reasons why your Verizon tablet keeps disconnecting from Wi-Fi and not accepting your password to reconnect. Here are some possible solutions:
  1. Restart your tablet and your Wi-Fi router: Sometimes, simply restarting your tablet and router can help resolve connectivity issues.
  2. Check your Wi-Fi signal strength: Weak Wi-Fi signal strength can cause frequent disconnections. Move closer to the router or try to improve the signal strength by repositioning the router or using a Wi-Fi signal booster.
  3. Check your Wi-Fi network settings: Check if your Wi-Fi network settings match those of your router. Make sure you have the correct security settings and password. Try to forget the network and then reconnect and re-enter your password.
  4. Clear your tablet's cache: Clearing your tablet's cache can sometimes help with connectivity issues. You can do this by going to Settings > Storage > Cached data > Clear cached data.
  5. Check for software updates: Make sure that your tablet is running the latest software updates. Check for updates in Settings > System updates.
  6. Factory reset: As a last resort, you can try doing a factory reset on your tablet. This will erase all data on the tablet, so make sure to back up any important files before doing this. Go to Settings > Backup & reset > Factory data reset.
If none of these solutions work, you may want to contact Verizon customer support for further assistance.
1helpful
What are the side effects to Talam tablets
This is something that should be discussed between patient and doctor. The potential side effects of it are outweighed by the benefits, if the medication is effective and can be tolerated by the patient. These types of medications very likely should not be stopped without consultation with the physician. There is not only the risk posed from a lack of treatment of what has been diagnosed but also a risk of an effect produced by stopping the use without some mitigating attention from a physician.
Bear in mind that if one reads the potential side effects of most medicines, it tends to ring alarm bells. That is why the use must be monitored by a physician so that the physician may change dosage or medications if a particular side effect appears. Those warnings don't mean you will experience the side effects, necessarily.
The following is the generic name for the tablets.
Citalopram Tablets FDA prescribing information side effects and uses
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
Connect my samsung galaxy S Tab 2 to my Proscan TV 32LB45Q
It should be pretty much straight forward.
Can you check by setting both tablet and TV to 720p or 1080i?
I am not sure both can support 1080p
How to Connect Tablet to TV using HDMI Easy Fun
2 WAYS TO CONNECT PHONES TABLETS TO TV wire vs wireless review
2answers
How do I move photos from my tablet to the SD card?
Download ES File Explorer. Locate the folder where the pictures are, long press each file or select all by default, copy and paste files from the table to the SD card within the tablet. Alternatively, you can connect your tablet to your PC and access it via the PCs file explorer in the same way you would enter files within your hard drive. Copy and paste the files or drag and drop from the table to your PC.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Can i transfer my pictures from the gallery on my tablet to a flash drive
Yes, but it takes several steps to transfer pics from your tablet to a flash drive.
There are two ways of accessing tablet files: 1) wireless access which requires a sync app on your tablet and PC software of the same app type. One such app for sync between Android (any) to/from PC software is Cheetah Sync: http://www.jrtstudio.com/cheetah-sync-android-wireless-sync.
Alternatively, you can use ES File Explorer's Network/LAN/Cloud/FTP functions to share files between your Android phone/tablet and your PC via secure Wifi: http://www.cnet.com/how-to/share-files-between-android-and-windows-with-es-file-explorer/
or 2) wired via the USB charging cable, which I will explain in more detail:
Plug your table to your PC using the Samsung charger cable that doubles as a data transfer cable when you remove the USB plug from the wall charger cube and plug it to the USB port on your PC.
Your PC should read your tablet as an external drive: Open "My Computer" and double-click the tablet drive icon>search your subfolders for your pictures. Highlight your picture files and either copy and paste or drag and drop (different way of copy/paste) to your desktop (or desired location), copies will be transferred but not moved from the tablet unless you "cut and paste" from your table to PC to clear out your tablet and make more space. When done, unplug your tablet cable from the PC. Plug in your flash drive to the available USB port: access the flash drive icon on My Computer. Drag and drop or copy and paste picture files to your flash drive.
1helpful
2answers
How to transfer pictures from tablet to pc?
use either the micro usb cable you use to charge it as a data cable (so basically your pc will think the tablet is an external hard drive or camera) or save your photo's onto a micro SD hard inside the tablet, then take it out and put it in a card reader attached/connected to the pc....or send all your photos (while online) to a 'cloud' or 'drop box' type account and then download from that account to your PC
Tablet PC 2005 Input Panel won't work.
Are you pressing down firmly enough? If not, sounds like the digitizer may have a problem... The digitizer is the layer in front of the lcd, it's job is to pick up the signal from your pen and send it to the motherboard. The motherboard should have two connections to the screen, one to the lcd itself and another to the digitizer. If you remove the screws on the bottom of the tablet you can take off the keyboard and see if both are connected right.
Top Fujitsu Tablets & eReaders Experts
k24674
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
