https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Hi,At printer start, receive the following message: PRINTER ERROR 54.18.
According to the HP error code message reference, this is a black
cartridge sensor malfunction. Cleaned the sensor contacts, replaced the
cartridge and rebooted; same error. Is there another fix for this?
What is the error message? SCANNER ERROR? If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
