Thule 2003 Chevy S10 Pickup - Crew cab - Xsporter Truck Rack Logo
A
Anonymous Posted on Sep 23, 2014
2003 chevy s10 starter turns but does not fire sometimes
John farrow
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Oct 29, 2014
John farrow
Expert
Level 2:
New Friend:
Answers
55
Questions
Helped
15029
Points
116
Could be a fuel pump, or fuel filter. Check them both, also your injectors may me dirty. Check your fuel filter, also CHECK your spark plugs.
Starter relay 92 Chevy S10 4 cylinder
what transmission, here. automatic or manual stick shift?
S10 not blazer S10
old cars this old (pre digital documents) are hard to find and when found are not complete. or poor .
A/T box?
the PRNDL switch must be good. and cranks in both Park and neutral.
yes the relay clicks too, if not the PRNDL is prime bad part.
there is fuse named CRANK.(1st inline here)
the starter can be hot wired (a test) to prove starter work.
if stick shift TRANNY it is called the clutch switch. to crank,
some books say hood up fire wall, center is relay. IDK
see why we ASK transmission first/
if the relay does not click the fuse crank blown
or PRNDL is dead only on P mode, try N.
if stick shift,, clutch CCP switch bad or just mal-adjusted.
ST below goes to the relay then to starter solenoid
the relay colors are there. Green or Purple.
1992-undefined-undefined-0.jpg PRNDL is on side of TANNY part of shift linkage.
Chevy s10 wont turn over. transmisson line burst. lost all oil. replaced line and topped up oil. put in new starter and still wont turn over. i am wondering if engine could be siezed?
I doubt if the engine is seized but with the loss of oil in the transmission it could be a seized bush/ bearing in the torque converter or input to the ransmission
1helpful
2answers
My 2003 s10 started glitching. The instrument panel jumps, off and on, the rpm and speed gauage flicker off and on. Now it will not start.
Bad ground wires. Inside they will be at the steering column under the dash. And on on each side behind the side kick panels. Also check the battery to body ground and engine to body ground.
Chevy s10 will not start. turns over fires and then dies
Turn the key to on /run position. Remove gas cap and listen for a humming noise. If nothing is heard then the likelihood is the fuel pump is bad. But before removing the fuel tank, check all the relays and fuses for fuel. If that all checks out as good, then check the entire ignition system (cap, rotor, wires, and coil.
The injectors wont fire on my 1998 chevy s10 zr2
Is it happening on all cylinders? Or just one? Have you removed the injector an inspected it. I have never heard of all going bad at once. It would be a good idea to look for open fuses. The main connector is connected properly, each one has good connection.have you changed something lately?
Chevy s10 clicks when attempting to start
Its possible that you have a bad starter. I would start there, and go from there. good luck
2helpful
How do you get to the torque converter bolts on a chevy s10 blazer 2003?
If you remove the starter, you can access the bolts through the starter drive hole... it isn't easy, but definitely possible.
2003 chevy s10 turn key engine does nothing
could be a couple of thing,maybe your battery going bad,your ignition switch could be going bad,or possibly your starter.
1helpful
STARTING PROBLEMS WITH CHEVY S10 2003
first you need to check if your are getting spark, then go to fuel pressure, you should have 60lb of pressure
Top Thule Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Thule Boating Expert? Answer questions, earn points and help others
