Question about Fender Rumble 100 Bass Guitar Amplifier
Feedback overpowers amp output...I have fixed my guitars, fixed and replaced chords, tried other amps, tried other guitars, and nothing seems to fix the problem...If there a way to switch polarity on this amp? or is there any other solutions to this problem?
  • Fender Master
  • 5,603 Answers
I suspect you have a power supply problem given your symptoms.
The input jack should NOT be a problem with nothing plugged in, however the jack is suppose to ground the input with nothing plugged in. Since you have plugged stuff in with no change, I have to go with a power supply problem which is likely a bad capacitor someplace in the circuit. This will take electrical analysis and unless you are adept, you probably need to take it in for servicing.
Posted on Jul 26, 2009
  • 73 Answers
Hi there. If there is still feedback with nothing plugged into the amp, the problem is internal to the amp. Probably worn input jack or intermittent connector internal. Try thumping on amp with nothing hooked up. (guitar)
Thanks
Paul
Posted on Jul 11, 2009
6ya staff
SOURCE:
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
My passport 250 goes into protect mode on occasion. The other night at a gig it would clip into protect as soon as I sent a signal from the mic or guitar. It works fine at home. Is the unit sensitive to...
These seem to be tempermental. I would look for radio frequency interference from nearby transmitter leaking into your guitar cable or mic cable that puts this on the ragged edge of feedback. DO NOT boost highs with the EQ... You can get supersonic feedback that you can't hear, but puts the amp into limiting. Any audio input can start the feedback. These amps are VERY hard to work on due to the packaging. A lot of people have smoked their units and then require repairing.
May 24, 2011 | Fender Pd250 Passport Deluxe 250watt...
When I plug in my guitar to the Fender Frontman 64R Amp and I just barely move the cord, it make this really loud screeching type noise. It's not an old amp; I got it about five months ago. I can't...
Yes, there are several possibilities. First thing is to disconnect your guitar and then plug in the cord to the amp. Expect a bit of hum. If it screeches, then problem is not feedback via the guitar. If it doesn't MAYBE your guitar is "hearing the amp" which the guitar is then a microphone and can feedback. Moving the cable generates electrical noise which can trigger the feedback to start.
If you get the screech without the guitar connected, then TRY a new guitar cable. Make sure it is an INSTRUMENT cable... I have seen some try to use speaker cables or junky 1/4 inch cables intended for home stereo... these will NOT work and can cause the feedback. The next possibility is a broken jack on the amp. This would require repair. The common cause of this is to fail to run the cord through the handle of the amp... one trip on the cord or step on it pulling the plug sideways in the amp and the jack is broken and it is a trip to the shop as well. While on the subject ALWAYS run the cord at the guitar end either through the strap or your belt loop. Cords left dangling keep rotating and soon wear out the plug and also the jack in the guitar and then that has to go to the shop.
May 16, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My Line 6 Spider III 30W amp just quit on me. I know the speaker works, I know my guitar and chord work, but the amp doesn't. The amp will power up and all the lights will work, I can press the different...
Test the amp by touching the tip of the cord you unplug from the guitar and preferably try it with a second cable as well. If at high gain you don't get a loud hum, best to take unit for service. If it hums, then check battery in your guitar. The battery in the guitar is enabled when a cable is plugged in and MANY forget to unplug the cable from the guitar and have a dead battery within a day and blame the amp. This applies to most guitars that have preamps in them... there are some that are "passive" that do not have a battery.
Jan 24, 2011 | Line 6 Spider Iii 30
I am no longer able to turn on my amp. I was running a bass head through it a few months ago, and havent used it since. Now the amp wont turn on at all. I have tried turning the master volume down to 0,...
probolly all you did was run a head into another amp and just caused your marshall to overheat/overpower and blew your output transistor. i you drop the chassis out and look at the chip on the heatsink is it blown? also check all internal and external fuses.
Nov 24, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Amplifier Screech at High Volume
What you're hearing is FEEDBACK caused by the nearness of the guitar to the amplifier speaker. Always mute it when not in use, or don't move it close to the guitar amplifier speaker when unmuted.
Usually, even though you hear a high-pitched screech, the problem is actually caused by low frequencies, sometimes below the human hearing threshhold (i.e., subsonic) because they are more omnidirectional and thus more easily easily can loop between input (the guitar pickup, especially on a hollow-body guitar) and output (the speaker). The screech frequency is determined by the distance between input and output, determining how quickly the output reaches the input (then loops around through the amplifier). Therefore, reducing the BASS a bit will often alleviate some of the problem.
This is basically the same type of feedback heard when a microphone is turned up too loudly or the mic is pointed at the PA speaker. Avoid those actions and your feedback will be minimized.
Only time and experience will allow you to automatically take actions to avoid feedback. I worked in the San Francisco Bay Area as a manager and sound man for rock bands and several nightclubs for 22 years. My college major was Physics (which includes acoustics).
Keep on rockin'!
Feb 10, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My electric guitar wont play with my amp
Yes its probably the wirring but if u look at it
it kinda crazy, so you wont be able to do it on ur own unkess ur a guitar tech so just go to a shop and they will fix it for u, problem is that if it is the wirring it willl have problems, so u might want to replace the WHOLE wirring system... Depending on the guitar u have, FENDER< GIBSON<IBANEZ, CORT, the wiring colors will be different
DONT TRY TO FIX IT URSLEF
Jan 05, 2010 | First Act Music
I have a marshall avt 100 which was working fine until i plugged new guitar in strummed one chord and the speaker went **** up, so i plugged into another cab and played a while then a week later plugged in...
This is a problem I would recommend for a qualified Marshall amp service person to look at. Worst case scenario is that somehow the speaker out put transformer or the power transformer burned out. They aside from output tubes are the most expensive parts to replace. Add shop labor on top. Ask for an estimate first. Consider how much a new amp will cost and then decide. I would personally go for the repair myself.
Nov 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Fender Rumble 100 Bass Guitar Amplifier Logo
175 people viewed this question
Top Fender Music Experts
Michial Gueffroy
rjivaro
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
