I need a replace the foam of the speaker for my console and I am stuck at the size of the Speakers...Can anyone help me please...Does anyone have Service Manual for the Same.....Thanks in Advance...
Search ebay you can find them there.I don't remember the size and the specs but here is an example link on my random search
Hi Nishant,I measured the good speaker foam and this is what I got,the big diameter is 3 ",the hump,then the small diameter is 2-1/8" .I hope this helps you..if you are able to get them please tell me.Good luck Nishant.
I would mearsure it with a tape measure to be sure
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
SOURCE: Broken Speaker
The only thing I can suggest is go to www.harmankardon.com contact customer support and the technical department for answers, also try www.ebay.com Type: make and model and see what pops up.
