Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
My screen is getting darker. i have changed light bulb recently.
How to clean inside
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
How to clean lens on rca projection tv model# p61960 ?
Unless something got spilled inside the TV, I suggest you think otherwise about cleaning inside the TV. You will only make things worse by doing so.
Aug 21, 2014 | Televison & Video
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
Unscrew the entire lens assembly from the body. The inner lens cannot get debris inside it but the outside of it and the inside of the protector lens can. It's a good idea to do this cleaning in your bathroom with the shower on hot but not visibly steamy as this will cut the airborne dust by 90%.
Feb 22, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
How to clean inside of oven
dont use anything with lemon in it. this erode the enamel
Feb 11, 2010 | Thermador PDR486GLZS Dual Fuel (Electric...
I would like to clean inside my oven on the top
if you have a self clean oven, do not use an abrasive cleaner to clean
I would recommend running a self clean cycle, and anything left
"Mr. Clean Magic eraser" should take care of it.
it works miracles in ovens
May 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cleaning carbon off inside rollers of HP 1020
Pry up at the ends. Don't get the roller wet.
Jan 30, 2009 | HP LaserJet 1020 Printer
Cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Aug 31, 2008 | HP Photosmart 2610 All-In-One InkJet...
Dirt on the inside screen
Usually the best way is to remove the top back cover and clean the inside of the screen with a clean, dry cloth, but be careful because the mirror is mounted on the inside of the top back cover.
Jun 21, 2007 | Panasonic PT-51HX41 51" Rear Projection...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
