Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
A
Anonymous Posted on Sep 23, 2014
How do i connect my bluetooth motorola to my samsung SGH S275M PHONE
  • Official Brand Answer 1,623 Answers
  • Posted on Sep 24, 2014
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350380
Points
5677
Put your headset in Pairing mode by longpressing the multifunction button until the light glows steadily blue. Turn on Bluetooth on the phone and have it search. When the headset is located. Select it and then enter 0000 when asked for a PIN code.
You may also find directions at http://www.motorola.com/support
Motorola Support
I can not play music in bluetooth headset in samsung sgh j600 in my phone..!! Pls help..!!
hi ajit is here if ur bluetooth is not connect 1st on the bluetooth device n phone bluetooth press the bluetooth suplly key when u not se continous lite after thie search bluetooth n connect password is may be 0000 otherwise some hardware problem because of fall on the surface
5helpful
Pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
Mar 06, 2009 • Cell Phones
I need to connect a motorola H550 bluetooth with my samsung SGH p207 cel phone i dont have instructions
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth haedset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will some up like motorola h550 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya if i have fixed ur problem
2helpful
My samsung a737 doesnt see motorolla h500 bluetooth
If the bluetooth you are connecting to is a Motorola 500, the trick was to HOLD the "on" button while the phone was searching for the device. Turn on the Motorola device and keep holding the on button while the phone searches. Then enter 0000 as the pin into the phone when prompted.
22helpful
3answers
My phone bluthooth not work
my bluetoth not stoped working in my samsung sgh-820 phone can't detect aor connect to any bluethooth
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
2answers
PAIRED MOTOROLA BLUETOOTH WITH SAMSUNG
hold down the connect button on the bluetooth tl the light stays on, then open the boom, release the button. The light should stay on now, and your phone should be able to find you bluetooth.
Motorola H350 connecting to my samsung
well idk cuzz i cant connect it with my samsung SGH-A707
2answers
Bluetooth
removing the bluetooth is as simple as this:
menu, settings, connectivity, bluetooth, my devices, press down to get to the device you want to delete, press options, then delete.
h700:
menu, settings, connectivity, bluetooth, my devices, (should have at the top: search for new devices scrolling). Click that:
h700 bluetooth should be in pairing mode:
hold the center button down and wait for it to turn solid blue: the go back and search for new devices on the phone, when it finds the bluetooth, enter 4 0000 zeros for the passcode. The click if you want it to automatically connect or not.
Your done!
Clint Cartee
Bluetooth
hello iam having trouble activating my bluetooth
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
