GE 29875GE Digital Answering Machine Logo
A
Anonymous Posted on Sep 24, 2014
HOME DIGITAL TELEPHONE ANSWERING MACHINE LOCATION IN ARROYO GRANDE CA TO BUY PHONE ANSWERING MACHINE?
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Jul 08, 2008
SOURCE: Binatone Style 1210 Triple Digital Cordless Telephone With Answer Machine - Black
You can download a manual from the Binatone website.
Anonymous
  • 1901 Answers
  • Posted on Nov 13, 2008
SOURCE: how to connect the answering machine to my telephone
You should have two jacks on your answering machine. One should be marked "Line". Plug the telephone cord from your wall into this one. The other jack should be marked "Phone". You will need another telephone cord to plug into this and then connect the other end to the phone.
Anonymous
  • 172 Answers
  • Posted on Aug 11, 2009
SOURCE: answering machine leaves the telephone line open
Chances are it did not damage the control(operating) curcuits, but most likely the Telephone curcuits in the answering machine.
Anonymous
  • 18 Answers
  • Posted on Mar 05, 2010
SOURCE: Need used manual for GE Cordless telephone with
http://googleads.g.doubleclick.net/aclk?sa=l&ai=BsgZFEGmQS6eyK8rw-AaJ8cnoB8eVq6oBvcn2ghTAjbcBwKIzEAEYCSDqn5ALKAY4AFDdpeqhA2C7vq6D0AqyARZ3d3cuY29uc3VtZXJzZWFyY2guY29tyAEB2gE0aHR0cDovL3d3dy5jb25zdW1lcnNlYXJjaC5jb20vY29yZGxlc3MtcGhvbmVzL3Jldmlld4ACAakCEbzqUPBFuT6oAwHoA4ED6ANO6APhAugDhgP1AwQEAEQ&num=9&sig=AGiWqtzcRVuUOCVEV9lEqCKp1aa7kU54DQ&client=ca-consumersearch&adurl=http://telecomspares.com/index.php%3Fmain_page%3Dindex%26cPath%3D66_113
Anonymous
  • Posted on Aug 01, 2010
SOURCE: The answering machine keeps beeping and won't initialize.
NO !!!
3helpful
How do I retrieve messages when I am away from home? Model # EXA15580
Remote access away from home first you must enter the PIN code: 1) Enter the Answer Setup menu, and then the Security Code submenu 2) Enter a two-digit PIN code (01-99) using the number keypad (0-9). 3)Press OK
You can operate your answering system from a remote location using any touch-tone telephone. 1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps. 2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds 3)listen to the instructions from there (to play incoming messages, press zero-two)
CAN I CALL MY HOME FROM ANOTHER PHONE AND LISTEN TO MY MESSAGES.
Yes. Dial your telephone number. When the system answer, enter your three-digit access code during or after the announcement. The system announces the number of messages and begins playback. For full details, see the manual.
You can download a copy of the manual from
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=21714
I have a VTech Dect 6.0 cordless phone answering machine. I disconnected the power to the answering machine in error. I want to reset the time on the answering machine. How do I do this? My email...
Hi there,From answering your telephonemag-glass_10x10.gif when you are busy or away, to broadcasting a generic message to callers, an answering machine is a key part of your home or office phone system. When the device is working properly, it not only records and playbacks messages, but also informs you of the date and time of the call. If your answering machine is not recording messages, displaying an error code or is presenting another problem, you can reset the device and restore it to a working state.
1helpful
Answering machine leaves the telephone line open
The phone ring is heard when a message is taken
It was a fax that I didn't hear until I was home when the answering machine went on. It answered at the same time as the answering machine.
When I install 2 telephone, the telephones start to dial
might be the IP funtion, not available in the USA. so u being in france, (assuming you are)..it should work. but if that is the problem, try turning off this funtion. press SET/SAVE, press Up to SET 4 AUTO IP, then press SET/SAVE again to select, then press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main view. i have emailed you a copy of the manual i have. hope it helps.
tammy
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
