Question about Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer
Timer lot is on- won't start
The timer light is on, What does it mean and how can I turn it off?
    Habit-Forming:
    New Friend:
  • 77 Answers
The timer s a delay in starting your wash load
Posted on Sep 25, 2014
6ya staff
SOURCE:
Ok my 1983 camaro has a v6 in it and every time I want to start it I have to hook it up to a portable battery charger and start it up like that but now it won't even start up. Even when the battery is...
Sounds as though the battery is no good,
unless you know otherwise & also had it tested
Charging a battery doesn't address it's internal
condition
You have battery cables that corrode inside & can be
voltage drop tested
You have the starter & solenoid,ignition sw & such, to name
a few,lots of possible causes & things to check
Jul 24, 2013 | Cars & Trucks
I tried to start my car this morning. There was no electricity at all and i mean at all, The power locks won't even work nothing. The car won't start, it's perfectly silent when you turn
You would need to use a meter or test light to find out what exactly is dead. It could be a short in the fuse box, or a bad connection in the harness, or at the battery or starter.
You may need a repair book or shop manual to get the wiring diagrams.
If nothing on the truck works, you would start at the battery cables and work back to the key switch.
Mar 03, 2013 | 2001 Mazda Tribute
Digital timer stuck on 10 min.won't start the spin cycle
I know this isn't the solution you were hoping for but here is the manual for your machine:
http://www.samsung.com/ca/consumer/home-appliances/washers-dryers/washers/WF203ANW/XAC-supportforward
You say it rotates L & R...do you mean it agitates but the timer isn't advancing?
Dec 30, 2012 | Samsung WF203ANW Front Load Washer
93 suburban no power won't start no lights etc.
Some vehicles have a 50 to 60 amp main power fuse would check for that.
Aug 03, 2017 | Cars & Trucks
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Light won't turn on or off
Where is light located?
What is light used for?
What voltage?
Is this light inside home?
Is there a timer?
What brand and model timer?
Add a comment and describe timer.
Is this an old timer that stopped working, or a new timer that might be wired wrong?
Is light bulb good?
have you tried different light bulb?
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-wire-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 27, 2012 | Hardware & Accessories
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
Won't start
Make & model number would help. What do you mean NOT WORKING...not cooling, not operating, no cavity light...etc. Could be many issues, if there is cavity light then there is power to unit. Other items...compressor start device, cold control, defrost timer, rodent issues. Fan issues.
Mar 29, 2012 | Refrigerators
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Any idea why it takes a few turns of the key to start my truck? There is 59000 miles on it and the last 2 mornings the truck did not want to turn over. it eventually did, and would start fine in the work...
You have to be specific about the engine turning over
That is done by the starter circuit
Some people call that cranking
Some people also say it won't crank, when they mean
it does crank, but won't start
Not turn over the engine -----
Old & Weak Battery
Dirty Battery Cables
Worn out Starter Solenoid -- you can buy & replace
without getting the entire starter
A bad Starter
Sep 22, 2011 | 2007 Lincoln Navigator Ultimate 4x4
Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
80 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
