Incoming calls are coming into one phone we need two phones to ring
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
SOURCE: Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
SOURCE: MERIDIAN M7324
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
SOURCE: Only First Phone in the system will ring on incoming calls
No the manuals locates on the norstar website are just the tutorial telling theat hte hold button put a person on hold...we all know what the function of a hold button is or even a line button is...if someone has some real information please submit it! Oh and i have already tried calling norstar...they tell you to call meridian, then meridian tells you to call norstar...great customer service!
SOURCE: I need to change which phone rings.
I guess this is alittle late... but for your knowledge:
First you need to know the extension of the phone that you want to change. Feature 0 at the phone you want to change and hit the intercom key to ensure that we are programming the right phone.
To get into programming press:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading..Enter->
<- Back .......Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension number of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Enter (the top right arrow) again then LINE ASSIGNMENT and hit Enter again
-> then you will see Show line:____ and input 001
-> it will show something like L001: Unassigned now press CHANGE till it says Appear&Ring
-> keep putting in all the lines that you want to ring at your desk
till all the lines are found (the numbering scheme counts out funny for Norstar it goes: line 001,002,003,004,025,026,027,028)
-> after you find all the Lines, you now hit RLS to back out of programming.
Voila, your phone will now ring. To change back, do all the same steps, but input Unassigned instead of Appear&Ring.
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
