59.co error turn off then on
The product has experienced a developer motor error
Turn off the power and wait 30 seconds or so and power back on.
if the unit still errors you have a bad developer motor or the DC Controller (board that drives the motor) is bad. the unit might not be wort the cost of repair but I have included the part numbers.
motor: RL1-1800-000CN
DC Controller:RM1-5431-000CN
SOURCE: How do I fix the chronic error message 59.CO on HP
Developer Motor error.
Power off for 30 seconds. Power on, if error persists get the developer motor replaced.
If the problem still doesn't go away replace the DC Controller.
In other words, get a tech to look at it.
SOURCE: hp color laserjet 3800 Give err 59.co
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
