Can you please deliver our zenith 27 inch large TV. were at metro tech high school our address in 1900 Thomas . RD Phoenix Arizona 85015 number to metro tech. is 602-764-8000 and number to attendance to hot line. is 602-764-8025please send me TV with channel 3-5-8-10-12. please send me MBR remote control but I just want a. cartwright mbr remote control please send me one for MS miller tucker sincerely. joie please emergence
SOURCE: Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
SOURCE: Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
SOURCE: 27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
SOURCE: need remote codes for Zenith B27A11Z 27
001,004,089,099,105,177,197,200,....hope this helps....
