Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony tv kv-36fs120 will not turn on
Standby light blinks 8 times then some times blinks 9 times no noise at all like will not even try to power on tried unplug for 1 min and 4 hour no help
  • 11 more comments
  • Anonymous Nov 11, 2007
    POWER ON LIGHT KEEP BLINKING TV NOT COMING ON
  • Anonymous Nov 14, 2007
    My TV will not turn on. The red standby light blinks 9 times, hesitates, blinks 9 times, hesitates, and just continues. I have tried to unplug the TV and waited to plug it in again with no results. The red light just starts blinking again and TV will not turn on.
  • Anonymous Dec 19, 2007
    Purchased TV 4 years ago. Can hear it click on but the picture never turns on and the power light goes on for a few seconds but then goes off - any ideas?
  • Anonymous Jan 12, 2008
    I HAVE A KV-36FS100 FLAT FD TRINITRON
    ONLY 5YEARS STANBY LIGHT BLINKS 5 TIMES THEN 2 BLINKS I HAVE UNPLUG UNIT AND IT STILL WILL NOT COME ON.
    I AM VERRY UNSATISFIED WITH SONY THAT I WILL NOT BUY ANOTHER SONY AGAIN.
  • Antboogie Apr 01, 2008
    I am having a probelm with my Sony TV. The Stand by/ Timer light continue to blink and the picture will not come up. I have sound and the cable it working but the TV is not. Please help. I have tried to turn the TV off for a few minutes and relplug it back up but it still does not work please help.
  • Anonymous Nov 22, 2008
    I AM HAVING A PROBLEM WITH MY SONY TV. THE STAND BY/ TIMER LIGHT CONTINUE TO BLINK AND THE PICTURE WILL NOT COME UP.
  • henryphenry Nov 30, 2008
    Same thing 9 blinks and a delay on the standby/timer light and it wont go on
  • tiger888 Dec 07, 2008
    Standby/timer light blinks, with no picture and sound, power on and off won't help. Can replacing fuse work? Thanks
  • lt one Dec 07, 2008
    my sony wega 50''has this problem.tv will stay on for about 40 seconds then picture goes away and power light starts blinking.it will blink approx,45 times then tv comes back on. it did this for about an hour.
  • Anonymous Jan 11, 2009
    I have the timer/standby light blink 5 times, pause, and then blink 4 times. I disconnect it and it stops but then does it again when turned on the next time
  • Anonymous Jan 19, 2009
    the stand by light is flashing all the time
  • Anonymous Feb 13, 2009
    sony kv-36fs76 u, 5yrs old, cost 1500gbp!!! - now randomly switches to standby with 5 red blinks ad nauseum. sony repairman checked for error code(he held down two of the set-top buttons & switched tv on to get 'engineer screen'). there was no error indicated, so he suggested binning the set & buying another! Never again a sony!!
  • gk92069 May 12, 2009
    My Sony Wega KD36XS955 HDTV went off the first time after about nine months of buying it (just under $2000 out the door!). Called Sony and the tech said:"unplug it and plug it back in then turn it on. It's common with that model". It worked, and in less than 4 years I've had the TV, it's done it a few more times and I'd unplg it, plug back in and it would work. Until now. No matter how long it's unplugged, it won't turn on. It flashes 3 times and that's it. The Sony tech originally said the degaussing system had to reset, and this last time we spoke after it wouldn't work anymore he said the 3 flashes indicated a bad "DZ board". I had a 2 year warranty that ran out and Sony recommended buying a new TV from them at a slight discount... thanks for the advice, Sony, but I'll never buy another Sony product, EVER!!!
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
Posted on Jan 24, 2009
Don't bother taking it to a repairman. The cost would be over $400 to fix. My Sony wasn't even three years old which is maddening since it cost $900+. I noticed another woman wrote in about the same problem and she was also quoted a repair of $400+. I didn't buy another Sony, that's for sure!
Posted on Dec 13, 2007
I just had the same problem. I went to the Sony website. It instructed me to unplug the TV for 60 seconds. I waited 10 munutes; plugged it back in and it worked.
Everyone may have already tried this and maybe it didn't work and I just got lucky
Posted on Jan 08, 2009
    New Friend:
  • 5 Answers
Standby light flashes and wont turn on
Posted on Apr 16, 2010
  • bstaber Aug 13, 2011
    OK so out Wega started failng to come on after shutting it off at night. It blinks 4 times Red. It never shuts off while I am watching it . 4 blinks means "running hot" I have cleaned the back of the TV with a vaccuum and it worked only to fail again the next day. I started finding posts that say the Humdity sensor in these Sony's is faulty. People have had luck with usuing a hair dryer ponted to the lower left hand corner (if your are facing the back panel of the TV. That never really worked for me. BUT what works for me is this, Take off the back panel, (10 screws) and vaccuum the fans (which all appear to be working) Then vacuum the left side fan and the area just to the right of it. The heat sensor is located near the Left sided fan. (It's a small round thing with wires going in and out of it. Bout as round as a quarter.) This has worked for me about a dozen times. I have just left the back panel held by 1 screw at this point. this will get me through til I buy a new S A M S U N G !!!!!!!
6ya staff
SOURCE:
Sony KV blinking red light
Probably defective power supply. Fixya is unable to recommend replacement parts sources.
Jan 24, 2018 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Nov 14, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony wega tv won't turn on. The standby light blinks six times..
sorry, 6 blinks is a bad board!!!will cost around 1000 bucks,just by a new set
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Thanks,
Dan
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-32FS13 will not power on
The set should have a blinking standby light when you attempt to turn it on. Please update this with the count and that should give me enough to propvide some details.
Dan
Mar 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Power on Sony TV Model KV 36FS120
Hiii....
The sympthon 9 blinks :
Check at G board : D6301 D6116 ( replace with new one !!!! ).Voltage around +/- 12 -13 v .
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Jan 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
2,970 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
