On Marlin-branded Model 60 rifles, the first two digits of the serial number indicate the year of manufacture. For example, if the serial number starts with 18... The 18 is significant, for subtracting it from 2000 gives the date of manufacture for the rifle, 1982. Likewise, a serial number starting with 17 would be a rifle manufactured in 1983.
This method has not been uniformly followed. It is valid only from 1971 through 1999. Prior to 1971, the first two digits indicated the year of manufacture. For example, a rifle with a serial number starting with 70... would have been made in 1970. Starting in 2000, this same old method has returned; the first two digits once more indicate the year of manufacture directly, with no subtraction required.
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
Marlins after 1948 use a system where you subtract the 1st two digits of the serial number from 100, to get the LAST two digits of the year it was made.
In your case, serial number 16370112 - 1st two digits = 16
100 - 16 = 84 = 1984
