Adjusting the sound level
Hey friend, thank you for your inquiry!
I see that you would like to adjust the chime on your Frigidaire washer. I researched the model number you provided, FFW5000QW but was unable to locate any information on it. Could you verify the model number for me please? You can locate your serial tag (which lists your model number) on the door frame of your washer with that information I can double-check to verify if the chime can be adjusted. -Matt
SOURCE: Water level
Your water level is adjusted automatically by the machine, you dont have any control over this. What yu need to see is to keep your wall faucet fully open before the wash, also check whether the pressure is good. It is normal that you see a low level thru your glass in machine............
SOURCE: Not enough water
It only causes an increase in my triple AAA rating......
A for annoyed
A appauled
A angered
If your clothes are not propertly washed it leads to skin manifestations. example neck face and head issues due to pillow cases that are not really clean. I have had it....................this is cleaning them daily. I think I am going to go find a wash board and wash my pillow cases by hand nothing like going back in time. Less water 2 hour cycles are they serious how is this saving money. I have to wash thing twice because they don't come clean. Yes I have used all the appropriate settings and detergents. I am going to have my husband go buy me a hose adapter and hook it to my bathroom sink and bypass this stupidity. I bet I good run the quick cycle and get things clean if I only had enough water.................
Cindi d
SOURCE: Washer (Amana NAV 5800) vibrates
We purchased an Amana NAV5800AWW top-loading washing Machine which ran fine for about 19 months, then it began to vibrate violently when it went into a high-speed spin. I went thru the "leveling" procedure, although it didn't need it; and when that didn't help called the appliance repair man.
The repair man tightened screws, checked that my floors were solid, and then checked the tub itself. He found that the inner (stainless steel) tub was loose, and upon closer inspection found that the stainless steel tub was severely "cracked" around around each of it's 4 mounting bolts. This was allowing the tub to move around, thereby creating an out-of-balance condition.
He indicated that the "fix" would be to replace the tub, which was still under warranty; but I would have to pay the labor for installation ($90 + tax). He suggested I might call customer service and see if they would pay the labor.
I called Whirlpool's customer service dept (Whirlpool bought out what used to be Amana). I spoke to the customer service agent and after explaining the problem suggested that since the problem was clearly either a manufacturing defect or an engineering design flaw, that the customer shouldn't have to pay anything. He (although courteous) said that the warrantly clearly stated that only the part (and not the labor) was covered, and that Whirlpool would not pay for the labor charges.
That's when I pointed out that it didn't project a very good image of a company (Whirlpool) when it would not bear the cost of fixing a problem clearly not of the customer's making. Moreover, I assured him that I would never purchase a Whirlpool product again; and that I would make certain that my experience found it's way onto the internet.
SOURCE: I can't get my Bosch Nexxt 700 Series washer to
Check your shocks that holds your tub up on the inside.
SOURCE: MY MAAYTAG HE FRONT LOADING WASHER DOES NOT GET
You could go to the service matters link and get the tech sheet or service manual for your machine
MAYTAG
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "thanks guru! I went to the seervicematters.com web site and found a tech manual for my machine. I believe it could be the flow meter that does not allow enough water. Front loader HE washers tumble the suspended dirt and grime back into the clothes. Beware potential purchasers, you cannot adjust water levels, manually!!"
Hello friend, thanks for your post!
I see you would like to adjust the water level on your Frigidaire washer. I have researched that question for you and there is not a way to adjust the water level inside of your washer. I hope this information is helpful. -Matt
