Key does not work
SOURCE: Powerbolt 1000 uses up batteries in a week
Get in touch with Weiser Canada via the contact info on their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). i have two rental properties with Powerbolt locks on them and have found - over the past 3 years - that it's safest to just replace the batteries on a 4 month schedule to ensure the tenants don't get locked out! The batteries actually last for longer than ~ 6 months, but i prefer to be on the safe side ...
Cheers,
SOURCE: How do I reprogram the
best of luck.
SOURCE: Weiser powerbolt worked well for
Hi...
You have too be sure that the deadbolt is free when it go inside the
deadbolt hole... however this system is very low power and the (over
torque clutch) will sleep if the deadbolt it's not completely free.
Also
if you try to open the door before you unlock it, you may block the the
deadbolt inside the deadbolt hole. Take care too unlock the door before
open-it...
Good lock or good unlock
SOURCE: i have a weiser lock
The
deadbolt may very free inside the deadbolt hole... This system is low
torque and a over torque clutch may slip if the dead bolt it's not
completely free inside the deadbolt hole... Also, if you try to open the
door before to unlock it, you may block the deadbolt... take care to
unlock the door before open it. to be sure that the dead lock is ok, you
can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Which will take you to the programming instructions for your Powerbolt 1000.
