Hello sangpark003 - Often when the unit is making a whistling noise, it is because it is pulling air from the outside. Sometimes a poor door gasket could be causing the whistling. You may check if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. However, if issue persists, I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts or to confirm if it is a normal operation noise.
