Windows Server 2003
SOURCE: Sata , ide
Initially connect only the sata drive from which you want to boot the OS. Establish the OS successful operation from this drive. Then connect the remaining drives in conventional way or the RAID array you want to have.
SOURCE: How to detect two IDE drives with same brand
Put both drives on the same ribbon cable, both drives set to cable select <CS>. the bios will then detect them as primary and secondary.New drives are RAW and therefore not detected by any Operating system until formated. You can use seatools from seagates website to install and format the drive or use disk manager in windows.
Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
SOURCE: Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
SOURCE: adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
SOURCE: New SATA hard Drive not recognized
hi! there,
try to check your i.d.e cable connection there several pin
connection sometime they are loosening,its good if you can replce new one.also the power supply cable,have a nice don,t forget to rate me thank's
Addendum
