To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
SOURCE: how do i fold a mutsty urban rider?
Hi, the trick
is to put the seat on correctly in the first place. If you look under
the front of the seat (when seat is facing away from mum/dad) you'll
see 2 plastic hooks - these need to be hooked over the first horizontal
bar of three that you can see (it has a small black plastic nobbly bit
on it) then, push the handle down and pull the 'tube' on the left up. If
the seat is facing you (child travelling backwards) it won't fold,
neither will it fold with the carry cot attached. To open up again you need to pull the little red lever on the left and open frame until it locks into place.
Hope this helps! Tegans mum x
