A Freezer usually has a condensor drain coming out of the compressor, that empties into a condensation dish underneeth, where condensation water is picked up and Re-evaporated.
It is most likely that your Drain is clogged.
Happened to me.
Have someone check your Drain, and if needed unclog it with a small prying tool into the tube.
Try removing the strap holding the drain hose underneath that drains into the pan. Otherwise it acts like a p-trap and holds water that then insulates the upper part of the tube. Condensate water eventually freezes high up in the tube and backs up everything pushing the condensate water into the bottom of the freezer where it freezes into sheets. Leaving the drain hose down keeps air in the tube all the way back up into the freezer area. This seems to keep the condensate water flowing freely into the bottom pan. The air in the open condensate tube does not seem to have an ill affects. Also, you can add some stranded bare copper wire around the heating element just above the drain tube inlet and then push the tail off the copper wire down into the drain tube hole. This helps keep any water in liquid form flowing down the drain pipe.
Check the condenser coil is clear and clean, and thermostat set about 2 or 3. Also check the fan is running with door closed, and no food is too close to the top stopping the airflow over the evaporator. It may be as simple as a blocked drain backing up - check the drain tube next time it defrosts.
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
You need to check the Condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximum efficiency and it is recommended to clean them every 6 to 10 months. If they are or have recently been cleaned then make sure the inside fan (if there is one) isn't being blocked by anything and make sure there is adequate airflow throughout the refrigerator.Also you need to make sure the copper coils behind the fan aren't freezing up either. If they are then there is probably a problem with the defrost element. The condensate drain may also be the cause of the problem. To find the condensate drain, remove the panel from where the cold air is coming out and there should be a tube or a hose that allows the condensate to drain out. If none of these seem to be the problem then you may have a refrigerant leak and you need a certified technician to take a look at it.
freezers still make condensation like air conditioners. they have a drain line heater to keep the condensate liquid until it exits the freezer. then it goes into a drain pain that usually has the high (hot) side line running through it to evaporate the water and at the same time increase efficiency. you probably have a rusted out drain pan which you can replace. you can make one from sheet metal and just seal the corners with RTV silicone, be careful sheet metal WILL cut you badly, so wear gloves whenever handling that stuff.
there is a condensate pan under the freezer, but when the compressor is on, the heat from the high-side line evaporates it. but still check to see if there is too much.
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
the water is coming from the freezer
when is defrosts. the drain line is in the back wall of the freezer and may be
clogged up with ice. clean out the freezer and pour some hot water in the very
back of the freezer, this will hopefully unclog the drain. if not, then you
have to take the back wall out of the freezer to get directly to the drain
line. there should just be a couple screws holding it; it is just an aluminum
or plastic panel. if you already checked this and think
it is a different problem then let me know, i will help you figure it out. Mike
