I need direction on how to get my coffee maker to work based on the above, Thank you
SOURCE: B60.Coffee maker was working fine untill
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
SOURCE: Coffee maker not working
I've got a B50 as well, and none of these solutions are quite accurate. The problem is with the ball valve directly above the top needle. You first need to remove the handle by taking out the screw on either side. Mine is some size of torks. Then open the hood and remove the two screws from under it. The hood then lifts right off the body. There is a rubber hose that goes into the top part of the ball valve; this must be removed. You can then use a slightly bent paper clip to reach in carefully and push the ball down to unstick it. It is being pushed up by a spring from underneath, so coming from the bottom with a paper clip just pushed it up tighter in the seat. Once it is clear again, put the hood and handle back on.
I think Keurig should send free replacement valves, maybe better designed as well so they don't stick anymore. If not, I am going to see if I can purchase a replacement.
SOURCE: My coffee maker suddenly stopped brewing.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
