SOURCE: Sony cdp 350 compact disc player will not spin to
There's never been a better time to switch to Juniper. Right now, you can reap the rewards of being a part of the new network - in just a few days. Juniper EX Series switches are standards based, so implementing them with your existing network is easy and seamless. And the benefits are huge. At least a 30% reduction in capital expenditures. Increased efficiency. Less energy consumed. And a network that's easier to maintain and operate. We'll work with you to find the most cost-effective solution for your specific needs. In return, you'll get a fully automated solution that readies your network for anything that lies ahead. You'll get your new switches in a couple of days - not in 6-8 weeks. And we'll be ready to provide any support you and your employees might need. Your network will be more streamlined, more efficient, and more cost-effective.
SOURCE: I have a Sony hi-fi
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective. The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer. Thank you for using Fixya
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
SOURCE: HI Have a Sony HCD H51 CD spin motor not turning
check the ic and the transistor that the motor feeds from they might be bad.good luck.
SOURCE: cd player won't spin disc
HelloCheck the sled motor. it is the motor that spins the disc inside, as soon as it has been loaded. Check the voltage comes to the leads of the motor first. If the voltage is there, and the motor does not spins, repalce the motor. It is a stepper motor, can be bought from most of the electronic spare part shops at your town. it is not a very colstly component. OK.
SOURCE: sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
