Question about Toshiba 62MX196 62 in HDTV DLP TV
My Toshiba DLP 62MX196 is not powering up and 3 yellow light keeps flashing continuous. Any sugestions ? Tks.
Yellow light 3 blinking repeted continuous,
    Master:
  • Toshiba Master
  • 689 Answers
Have you tried a new lamp?
part# 75007111 https://www.encompassparts.com/item/7209710/Toshiba/75007111/Y-196_Lamp_62Mx19 $199.00
Posted on Jan 03, 2015
Anonymous
SOURCE:
Anonymous
SOURCE: toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Posted on Nov 24, 2008
Steve Yocum
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
Anonymous
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
Anonymous
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 09, 2009
Toshiba model 62MX196 t.v. 62 inch rear projection...turns on then goes black and mute after 5 secs then red led continually blinks. Unplugging and rebooting power button causes a voice to say "fan st
I'M ASSUMING THIS IS A DLP? IF SO "ANY"
I REPEAT IF ANY OF THE FANS ARE SEIZED OR DRAGGING
SLOWER THAN THEY ARE SUPPOSED TO
IT WILL SHUT DOWN THE Tv!!!!! EVERYTIME AND THAT GOES FOR ALL OTHER DLP/LCD PROJECTION AS WELL!
BY DESIGN THEY DEPEND ON THOSE FANS, WITHOUT THEM THEY WILL BURN UP THE PARTS THAT THEY ARE ASSIGNED TO COOL. THE 3rd WIRE ON THE FAN PLUG SENDS A PULSE EVERYTIME THE FAN COMPLETES A 360 degree REVOLUTION, TO A CIRCUIT THAT MONITORS IT.
Nov 15, 2013 | Toshiba 46H84 46" Rear Projection...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 52hm95 will not come on , red light blinks
It is the Light assembly engine. Happened to me It is $700 to fix and the wanartee on the new part is 3 mos
Aug 13, 2009 | Toshiba 52HM95 52" HDTV Projection...
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Toshiba dlp 46 inch red light keeps blinking
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 62MX196 62 in HDTV DLP TV Logo
397 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
