I NEED A ORIGINAL DV LENS HOOD FOR PANASONIC AG-DVC7
SOURCE: need to replace lens
Hi!
The DVC7 has a 43mm filter thread on its lens. Depending on your Bower's thread size, you may need a step-up or step-down adapter ring to fit it to the DVC.
After checking if you have your sizes correct, you need to remove the DVC7's lens hood. After that, it's just a matter of screwing the wide angle lens to the DVC's lens.
Hope this helps!
SOURCE: Cannot find Driver to dump video onto hard drive
do u have a laptop with firewire port 1394 and port on the Camera it is there ,u can easily connect thru fire wire link with 4 pin cable cable buy a cheap one from store like 10 $ there is no need for buying a branded one bcoz quality is not compromised in any way this is digital signal, if u dont have the laptop with firewire then u have to spend more on PCMCIA FIREWIRE CARD for it or PCI firewire card for desktop which ever u like and then u also need a software to capture the video which i think u have in ur pc , no need for drivers just connect and it will be auto available in the capture devices list of the capturing software, just go and do it
bcoz ur camera is MINIDV TAPE there is no other option to get ut footage on PC for editing
pls rate me if u find me fixya problem
contact me for further help
SOURCE: lens hood broken off and I need replace ment part to screw it bac
you can email me a picture of the broken part and i will send you the part numbers of the broken parts here: [email protected]
SOURCE: Panasonic AG-DVC7 Mini DV Camcorder comes on with
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
SOURCE: WISH TO FIND OUT IF
I take the cover off the door, using the eraser as the end of a pencil - lightly press on the recording head (drum). Put a tape in and watch to see if the tape now wraps around the head and stays in position to record.
