Systemax Venture PC Desktop Logo
msfa Posted on Oct 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture. The system is on a 3 partition 320g IDE dirve and my data is on 2 Seagate Barracuda 2T
I sent this question but I think that I was misunderstood. I added more details.
Glyn
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 123 Answers
  • Posted on Oct 03, 2014
 Glyn
Expert
Level 2:
Cheetah:
Answers
123
Questions
0
Helped
32968
Points
253
You would need to re-install the operating system.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
I WANT TO INSTALL 2003 SERVER ON IBM X236 BUT IT IS SHOWING NO DRIVE PRESENT
Use the IBM configuration disk and it should be able to prepare the server for what ever OS you need to install. If you don't have it then, try redoing RAID and reformat the hard drives and try again..You can probably hit F6 during the initial portion of the install and supply the necessary SATA drivers on a floppy and get it to install. You will probably need a USB floppy though unless your server has a floppy drive.
Insert your Microsoft Server 2003 Installation disc into the CD/DVD-ROM drive and boot the server from the installation disc. Microsoft Setup will load the files it needs to perform an installation. Press "Enter" to setup and install Windows.
  • 2 Press "F8" to accept the Microsoft License Agreement.
  • 3 Create a new partition to install the operating system onto by selecting the "Unpartitioned Space" and pressing "C." If there is no unpartitioned space, highlight and delete all of the other partitions on the hard drive by pressing "D." Set the partition size to the "Maximum Size" and press "Enter."
  • 4 Format your new partition with the "NTFS" or the "NTFS (Quick)" option. Windows setup will format your hard drive and load the installation files. Your IBM Netfinity will restart and installation will continue.
  • 5 Select language and regional setup information, then press "Next." Enter your name and company name, then press "Next." Enter your Windows 2003 Server Product Key and press "Next."
  • 6 Select the licensing mode you would prefer to use and press "Next." Create an administrative account and password and press "Next." Enter the current time and time zone and press "Next."
  • 7 Setup your Network information by naming the server and defining how it will connect through the net. Press "Next" to navigate through the network setup screens. Windows Setup will finish the installation process and provide you with a log-in screen to use your computer.
  • If you delete old partitions from the hard drive to install Windows Server 2003, you will lose all information on those partitions.
    2helpful
    4answers
    Local Disk C running out of space but the D drive has plenty of space. How to make the D drive the primary partition? Os in on C drive windows Vista.
    Do you run Disk Cleanup regularly (once a month)? This will free up disk space on the C drive, it remover old temporary files and compressed files as well as other files.
    You can also move and save your data files to the D drive, so the C drive has only the operating system files and program files.
    6helpful
    2answers
    Systemax factory restore - how?
    Tap F4 repeatedly to launch the recovery console on SystemMax Machines with the recovery partition still intact. Then you should be able to restore the machine to factory defaults without a CD.
    No Audio
    I have a friend with a systemax, same thing happened to him.
    Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
    Let me know how it works out.
    Trying to install new Ultra-ATA hard drive on my six year old SysteMax Tiger PC.My BIOS recognizes the hard drive,but Windows XP will not install for some reason.I've been told to re-install the...
    update your system bios first. as far as parition magic's related error.. if you were you delete the parition and recreate it, you should be ok. What's the error message you receive when you try to install windows on it?
    My operating system will not load
    Try removing all of the hdds or just leave one that you think it works. See what happens.
    Top Systemax Computers & Internet Experts
    Ngoro
    Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
