Get messg 016-700 saying Memory Full..do you want to add more memory. Printer will not print. Messg. eventually disappears off of display, but returns every time you attempt to print anything.
Even a small text only page will not print? Powerfail and try it again. I sometimes get this if I attempt to print a large document with lots of complicated graphics. In this case, I simply break up the print job.
Try this, it may be a large print job held in memory.
Press to clear the message, cancel the current print job, and conduct the next print job, if any.
· Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
SOURCE: DELL 810 Printer problem
Go to the control panel, then go to administrative services , once you get there, then choose services. Scroll down until you find the print spooler. You then want to stop , and then restart that service. Should take care of your problem.
SOURCE: how do I clear data from my RAM disk on Dell 3100cn printer
The RAM for the printer is temporary.
turn off the printer and unplug the printer from the outlet. wait for 20 sec. plug the printer in and turn it on.
you can select in the printer properties page of the printer to print immediately instead of spool and print from the last page first. that will eliminated the ob store in the RAM.
