SOURCE: problems with Magellan Maestro? 4040 GPS power connection
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
SOURCE: unit is dead / no power and wont turn on with usb plugged in
the folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000,
4040, 4050 and 6000t
i fix these and many other magellan
gps daily so when considering
my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and
your magellan still wont start up after holding the power button while
its
plugged in for up to ten seconds and still does not start..read below
this
is actually a very common problem with these magellan power
ports...they are poor quality from the factory and always and i mean
always fail..the new ports that you find on ebay are 100% better then
the factory port.
if your able to replace that power port
yourself, you can get one HERE, if not, ask the fellow that
sells them for help.
due to some dubious "experts" on fixya, im
not permitted to help you directly, but please follow the link above to
get further help.
let me know if
you need more help or info
bill
EX
SOURCE: Magellan Maestro 4040 won't turn
hi jaykremer
The following advice pertains to the following magellan gps systems.
4040, 4050, 5310 and 6000t
its
this
the factory port.
get further help.
let me know if
Bill
EX
Standing Member of G.O.T.
Please Support Our Troops
