The left side of the screen is fine, but the right side is blacked out but also has vertical multi-colored lines running down it. Occasionally, the left side will temporarily show itself, but then fade out.
SOURCE: Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
SOURCE: My dell latitude d520 was working fine and now
if you tap the back of screen and it goes on and off chances are its loose ribbon cable ,
every time you open and close lid , it will tug on it a bit, if the light goes off then inverter problem
SOURCE: Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
SOURCE: I have about a 1 inch vertical white line on my
It's pretty difficult to fix if you're not very good with electronics.
It sounds to me like one of the cables leading from the graphics card to the monitor is broken so the monitor isn't getting a full signal.
Sounds to me like Dell have a ongoing problem with this. Is it still in warranty? If yes get an RMA number from them.
If not take it to a locan specialist, but they tend to charge a lot.
