No messages regarding toner cartridges or any other component needing to be replaced.... Regardless, tried replacing OPC Belt - it did not correct the problem.
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
SOURCE: color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
SOURCE: Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
SOURCE: Ricoh Aficio SP-C210SF
driver mismatch don't use the postscript driver unless you have the option installed as an option
SOURCE: trying to scan w/ Ricoh Aficio SP C210sf
Could be a driver issue. Go to: http://www.ricoh-usa.com/downloads/software.asp?tsn=Ricoh-usa and find, download and install the driver for your Ricoh device.
