Tablets & eReaders Logo
A
Anonymous Posted on Oct 02, 2014
Forgot password to my kindle fire. How do I reset
Forgot password to my kindle fire. How do I reset it?
askLuca
Level 1:
Habit-Forming:
New Friend:
  • Contributor 46 Answers
  • Posted on Oct 02, 2014
askLuca
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
46
Questions
0
Helped
10773
Points
57
1 Connect the Kindle Fire to your computer using a USB cable.
2 Wait for your computer to recognize the Kindle Fire device, and select the option that allows you to view the contents and data stored on the Kindle Fire.
3 Copy or move the Kindle Fire files you want backed up over to your computer's desktop or other location.
4 Right-click on the icon for your Kindle Fire located on your computer's desktop, and select "Remove" or "Eject."
5 Remove the micro-USB cable from your Kindle Fire. After you reset your Kindle Fire, you can follow these same steps to move your saved files back to the Kindle Fire from your computer.
Part 2 Reset the Kindle Fire
1 Tap on the "Quick Settings" icon on your Kindle Fire. The icon is shaped like a wheel, and is located in the status bar at the top of your Kindle Fire.
2 Tap on "More."
3 Tap on "Device."
4 Tap on "Reset to Factory Defaults."
5 Tap on "Erase Everything." Your Kindle Fire will reboot, and display a message that confirms the reset process.
When the Kindle Fire has finished resetting, it will reboot once again, and display the initial start-up screen.
  • Kevin Smith
    Kevin Smith Dec 10, 2020
    we provide technical help for a href="http://kindlesupporthelp.us/blogs/how-to-fix-kindle-4-1-3-wont-connect-to-wifi/">kindle 4.1.3
2answers
Why doesn't my Kindle Fire 6 recgonize my password?
Amazon.com: Customer Discussions: Kindle Fire won't accept my wi ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 16, 2011 - My Kindle Fire recognizes the signal but will not accept my password. I have consulted ..... In reply to an earlier post on Feb 6, 2012 7:32:42 PM PST ... I tried it and the Kindle still doesn't connect with my password. I was on the ... kindle won't connect with wi-fi
May 7, 2012
Help I forgot my password
Apr 11, 2012
Kindle Fire won't recognize wi-fi?
Jan 3, 2012
kindle doesn't recognize Amazon ...
Dec 25, 2011
More results from www.amazon.com
2answers
When screen opens it suddenly starts asking for a password. I have never used a password, don't have one and cannot unlock my Kindle Fire HD
Give enter to password, in blank, withoul inputting anything. Maybe it accepts it as password.
The other possiblity is that you've been pranked and someone defined a password
Here you have a tutorial for Password Remove:
Kindle Fire Password Remove
If you can't get the password, you should do a Factory Reset.
Here you have some video tutorials how to do
Kindle Fire HD How to Reset Back to Factory Settings
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
How to Factory Reset Amazon Kindle Fire Tablet Tutorial
2answers
I am trying to set my new Kindle. I forgot my amazon password.
You just need to go to Amazon.com and they have a password reset function available. Change the password for the Kindle account there.
1helpful
I didn't realize that was putting a pass word n .How can I open my kindle/
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
How to unlock kindle fire
Forgot my password
How do i unlock my screen i forgot my password
Note: Your Kindle Fire lock screen password or PIN is different from your Amazon account password.
Reset Your Kindle Fire Reset your Kindle Fire if you forgot your lock screen PIN or your parental controls password and need to regain access.
If you have any content not saved in your Kindle Library in the Cloud, be sure to transfer that content from your device to your computer via USB.
Important: Resetting your Kindle Fire will remove all content downloaded to it. Any content you purchased from Amazon is saved to your Kindle Library in the Cloud and will remain in the Cloud. You can download that content again if you register your Kindle Fire to your account again.
  1. From Home, swipe down from the top of the screen, and then tap More.
  2. Tap Device.
  3. Tap Reset to Factory Defaults, and then tap Erase Everything.
Your Kindle Fire will restart.
To use your Kindle Fire again, you'll need to connect wirelessly and register your Kindle Fire.
Forgot my password cannot get passed enterpassword to decrypt device
You can press down on the 5-way controller to see your password hint. If you still have trouble with your Kindle password, you should contact customer support phone line and they will help you reset it.
To reset your Kindle Fire if you don't have the password:
1. Press and release the power button to turn on the device or exit sleep mode.
2. In the password field, attempt to enter a password 4 times.
3. When password is incorrectly entered 4 times, you will be prompted to reset Kindle Fire.
4. Select "Ok reset".
Forgot pin to my kindle fire hd??
If you can't remember your lock screen password or PIN, you will need to reset your Kindle Fire.
Important: Resetting your Kindle Fire will remove your personal information (including your lock screen password or PIN), Amazon account information, and downloaded content and apps. Any content you purchased from Amazon is automatically saved to the Cloud. You can download that content when you register your Kindle Fire to your account again.
  1. From the lock screen, slide the Unlock Bar from right to left.
  2. Enter characters into the prompt ten times. You will receive several warning messages. Dismiss the warning messages, and continue entering characters into the prompt.
After you've entered the incorrect password or PIN ten times, your Kindle Fire will reset.
2answers
Forgot passcode
Kindle Fire:
Kindle Paperwhite:
If you can't remember the passcode for your Kindle you'll need to reset your device.
  1. Transfer from a Computer to Your Kindle Paperwhite.
  2. You can't reset your Kindle Paperwhite if Parental Controls are set. If you forget your password, reset your Kindle by entering "111222777" as the Parental Controls password.
    Important: Resetting your Kindle will remove all content downloaded to it. Any content that is already saved to Your Kindle Library in the Cloud will remain in the Cloud. You can download that content again if you register your Kindle to your account again.
    1. From Home, tap the Menu icon, and then tap Settings.
    2. Tap the Menu icon again, and then tap Reset Device. Your device will power off and power back on.
    To use your Kindle again, you'll need to connect wirelessly and register your Kindle.
2helpful
Need to reset kindle fire
To reset a Kindle Fire to factory default, tap "Settings" (the gear-shaped icon near the upper-right corner of the screen, then tap "More". Scroll down and tap "Device", then scroll down and tap "Reset to FActory Defaults".
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
