Dvd is not playing. Incorrect region is appearing on screen
SOURCE: incorrect region code DVD player
if you use a PAL broadcast system where you live ..Use the menu on dvd to set it to PAL system..If you use NTSC change it to NTSC .
This is how to make Philips DVD 622 region free so that it can play VCDs from all regions.
*Open CD tray by holding down "stop" button on the remote.
*Enter 2812
*Hold down "OK" button on the remote till 9 appears in the TV screen
*Turn off power of your DVD player
*Turn your DVD player on and it is region free now
SOURCE: incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
SOURCE: Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
SOURCE: cant play region 1 dvd's on my sony bdp-s350 player
check these guys out; they offer a mod kit to unlock regions 1-6 for the BD 350
www.multiregionupgrades.com
Located in the UK but world-wide shipping available
