After 10 mins washing regardless of the programme it makes a noise and stops the error code is 6E which is not mentioned in the manual. It spins and rinses okay
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
SOURCE: MY SAMSUNG P1453 WASHING MACHINE
Empty the debris filter at the bottom (take the bottom bit off and turn the dial thingy) There will be water coming out so put towels down.
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
