The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable. This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error persists, the display board has to be replaced.
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons: The drain pump must be defective/blocked The siphon would have got closed The control board would have got damaged OWI defective
Blocked waste outlet or maybe just a worn pump.
I fixed a new one today showing F4
I found a piece of broken glass stopping the waste pump.
Hope this helps
john
I think on those you can gain acces to the outlet hose through removing the right hand side panel, if you do this I would advise changing your pump that the hose connects to ad this is probably whats causing the f4.
