Epson Stylus D88 Photo Edition printer has both lights flashing and I cannot het the printer to work
Error lights Stylus inkjet C and D range printers are here Support Downloads Epson Stylus SX235W Epson
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my
C42UX printer, careful not to break anything. I use a flat blade
screwdriver to pry it apart; there are two-three tabs at the back and
two at the front. Gently push them in, and then using a bit of force
pry apart the cover.
2. Next I removed the two (2) waste ink pads.
They are located at the back on the left hand side. I used the flat
blade screwdriver to lift up the ink pads (they were soaked). Please
use rubber gloves as it gets very messy.
3. Next I took the pads to
the kitchen skin and washed them with just plain hot water until they
were white again. I just let the hot water run on them (the pads are
about three inches long).
4. Once washed I dried them using a hair
drier. (you could place it the sun for a few hours or on top of your
heater or maybe in a heated oven; (make sure you do not set it on fire
with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no
UX, choose it anyway).It will ask if you replaced with new pads; say
“YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary
un-plug the power cord from the back of the printer, wait 20 seconds.
Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
