Im looking for a parts list or repair manuel for the ms170. cant fins one anywhere. help!
SOURCE: Stihl MS250C Chainsaw works great won't turn off!
That wire should go to the kill switch. IT just grounds out the magento. See the on off switch, and put it back on there.
Testimonial: "Very quick thorough reply and very on top of his information!"
SOURCE: How do I replace the oil pump on a Stihl MS170
The oil pump is pressed in from the bottom. There is a special bolt and bracket to make sure the pump is set to the right depth. Your local dealer should bea able to get the tool for you but it will be cheaper to have the shop do the work.
PS it is more common on this saw to have a dull chain act like it is not getting enough oil than to have a bad oiler.
I am gold certified and have been doing repairs since before the ms series. I have only replaced two oilers in that time.
Good luck
JOE
www.arcolawn.com
