Mitsubishi WS-55819 55" Rear Projection Television Logo
Posted on Nov 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi ws 55819
I have a Mitsubishi WS 55819 HD 1080 and the picture has gone bad. It looks warped - blurry. Do you have a solution?
  • richsterling Nov 29, 2007
    The picture is warped and looks almost like double vision. It goes in and out. I need some help.
  • kaspur Dec 03, 2007
    Same Problem as described above. seems all but component input is affected. DVD through the component inputs work fine, anything else looks like trying to watch PAL on NTSC
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 16, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1709988
Points
8129
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
I have a Mitsubishi WS-55819 and the screen is curved and looks 3d. The colors are also blurry. When it warms up it looks better. Any suggestions?
It could just be the solder on the convergence ICs which needs to be reflowed. If that doesnt help then the ICs will need replacement. Your model uses 2 of the STK392-570 ICs. If you need further assistance please let me know.
Thanks
Sonny
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
2answers
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
1helpful
My t.v. wont turn on. I have a Mitsubishi, Medallion HD 1080. Model ws-65819.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
3helpful
Mitsbishi model ws-65819 HD 1080 medallion, wont turn on
3answers
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
