I don't have a Janome, but in general
if your seam has extra loops at the top
looks like ^-^-^-^
loosen the upper tension a bit and tighten the bobbin tension a bit.
If the extra loops are at the bottom
sort of like \/-\/-\/-
do the opposite - tighten the upper tension a bit and loosen the bobbin tension a bit.
The upper tension is easy; it's usually a dial with +/- numbers. The bobbin may be more difficult. For mine, it's a screw on the side of the bobbin case. A web search seems to indicate Janome is the same.
Practice on scraps of the same weight and use the same thread you're using on your project until you get the tension right.
good luck
Is it a three or four thread machine?
A three thread has little strength used as a seam.
On a four thread,basically, it is a tension problem. You need to ensure that the presser foot is in the up position before threading. The correct path is followed for all threads. You are using good quality thread. Reset the dials to 'normal tension' #3 or 4 .... then slowly work your way from there. The manual should offer advice on which tension to adjust to correct a particular problem.
