This is the first time it has let us down can play bought tape but can not record
SOURCE: Faulty Panasonic DMR-E85H
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
SOURCE: Recording from VHS to DVDR
Possibly dirty video heads. I would suggest that you run a head-cleaning tape through the VCR deck to shift surface dirt off the heads. If that doesn't work, or it sort of works, but not satisfactorily, unplug unit, carefully remove top cover, and with the VCR deck in view, gently clean the heads with a soft cloth or special cleaning stick (these look like flat q-tips but are intended for VCRs - available from electronics/hobby stores) and some alcohol (methylated spirit will work if that's all you got - but isopropyl alcohol is recommended - available from the same places as the sticks) clean the guides (gently so as not to disturb their alignment) clean the pinch roller/capstan shaft - CTL (on the right-hand side of the drum) and FE (left side) heads as well. The whole tape path should be carefully cleaned. Refit top cover (carefully), plug unit back into power, wait until it completes its startup/loading procedure, then put a tape in. You should now have a playback picture with the sound. You only need to do this as required if head-cleaning cassettes don't work properly.
If none of the above cures your problem, then the heads are abraded/worn - let's hope that isn't the case here. This model does not use a built-in head cleaner.
SOURCE: Last night I set it
Good day!!!
Please try to look for the set up menu either in the remote or in the dvd itself then look for the option which has a program setting for the clock or time then when you saw that try to on the timer and look what will gonna happen.
If the first solution did not help you try this procedure:
When you're done doing it observe what will happen and please contact me...
so that we can do a better solution.
Thank you...I will wait for your respond.
