It works ok sometimes then does it randomly
If the timer does not advance while the washer is in spin
cycle the timer probably needs to be replaced. Simpson
was based in Australia and closed in 2006. If I knew what
area you lived in I could possibly advise on where to find
parts and manuals.
Regards,
Dennis
Does it drain all the water out/ If not then check your pump filter.
SOURCE: simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Testimonial: "Hi ours is a front loader it has a filter inside the drum, which you have to align with the drum to get to i have checked that filter it just had lint it is impossible for anything as large as a sock to go further than that filter, i took the hose of the plastic mount and held it lower than the machine & all the water drained, plugged washer back in and started a load it actually filled up with water for about 1 minute then cut off again back to " end load ""
