SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
SOURCE: samsung wf328aaw
According to Samsung:
Your Washer has tried to fill but
was unsuccessful.
Make sure the water faucets are open all the
way. Check for kinked hoses.
Check the inlet screens on the fill hoses.
Of course, other things can cause the same code. Timer not supplying power to the water solenoids, solenoid water valve is defective, etc.
I would try hot fill, cold fill, warm fill. The above are the obvious.
Mr Boo
You can download the manual at:
http://www.samsung.com/us/support/download/supportDown.do?group=homeappliances&type=washersdryers&subtype=washers&model_nm=WF328AAW&mType=UM&dType=D&vType=R
SOURCE: what does nf mean?
NF = Not Full
Is displayed when machine does not fill with water in the allowed time. Could be low water pressure at the feed pipe. Could be dirt clogging the inlet hose screen. Could be that the faucet valve is not fully opened.
Let us know of your success!!
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
